km-6030 operational panel/control panel
  • Romel S.
    • Jul 2025
    does any body have an idea where i can buy a unit of km-6030 operational panel/control panel, i have a unit of km-6030working good till one day, the control panel or the touch screen/lcd doesnt work enymore, i try to pull out the control panel and make short some circuit of the machine to test whether if the machine is working and it works. and now i want to replace my km-6030 operational panel, but idont have idea where i can get it... any body have a clue that could help me ... thanks in advance........... ...
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    The problem is the operation tablet. The conductive adhesive for the cable was bad causing bad connection for the touch screen in high heat and humidity areas. The new ones use an epoxy. You need to find a Kyocera Dealer in your area for replacement of the touch screen part #302FB25191.
    My mission here on Earth is to help all you Dum-Dums!
