What in the world is the trick!!!. Have a CS-4035, & a comp.flash card. What do I have to do???
Firmware / Kyocera
For a KM 4035 Copy & paste the files, not the folder onto your card, take the right hand cover over the MF tray off, stick your card into the slot, switch the machine on and the firmware will download automatically.
Oh yea if you have formated your card make sure its in FAT and not FAT32..........
Good Luck..The gene pool could use a little chlorine. -
Thanks For The The Help Everyone. Turns Out... Card Was Formated In Fat32. ... Never Had A Problem Before Now W/this. Thanks Again!!!Comment
For the Kyocera you must use the buffolo CF cards all others will not work.Get your facts first, and then you can distort them as much as you please.Comment
nillane
Not true that you must use the Buffalo card. We het all our cards amemory and Hard drives from Memory Experts International. Best quality I have seen out there and pricing is great.
They even carry the HD70, HD10, hard drives and the new DDR memory for the new falcon 3 machines.
They have memory and hard drives for all Brands including the new HD-506 for the Konica C6500 at 300-400 bucks cheaper then Konica. Woth the savings.......
Give them a call; Memory Experts International: 888-422-6726Comment
We usually get the SanDisk at RiteAide.We have been using the 32mb and 128mb for years.And the price ain't too bad , either.Comment
