Mita 4090
  • Sly Melson
    • Jun 2025
    Mita 4090
    Have mita 4090 with service code sc 510 check charge corna no wires broken
    thanks
  • 10871087
    • Jan 2005
    • 1143
    I think a c510 code is the s/t charger, pull both corona assemblies completely out of the machine, does the code go away?
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      C510 is the Main Charger leaking or broken wire. C520 is for the Transfer Charger. Could be the connection block on the rear of the machine or bad Main high voltage transformer PCB. I would look at the connection block on the rear frame. Also don't forget about a damaged drum causing arching.....
      My mission here on Earth is to help all you Dum-Dums!
