km-1620_C_0180 error
  • jewen25
    • Mar 2009
    • 197
    maybe the EEProm is damage,pls help me if this can reset or reprogram the Pwb board? pls me wht to do?or there a software available to re program or reset the board problem
    ERROR HELP ME AND HELP YOU
  • Frits
    • Jun 2009
    • 62
    Did you some how change one of the eeprom,s
    This is a machine serialnumber mismatch between to EEprom's
    • Absurd
      Just a brick in the wall
      • Oct 2007
      • 118
      I had this happen on a 3040 the other day. turned out it was a mc short that caused the eng. board eeprom to lose info so I had to go to sim 004 and re send the s.n. to the eeprom. to do this you just go to the sim and hit print twice. This is how i fixed a c180 and then discovered the mc had shorted out and was probably responsible for the c180.
      Southern Duplicating of Mississippi
      PSN: DrAbsurd (if you know you know)
      "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
      • jewen25
        • Mar 2009
        • 197
        no i did not change,how fix if have mismatch signal? what to do?
        • jewen25
          • Mar 2009
          • 197
          how to do this in km-1620? or to resend his signal? pls send me its process or attach how to this?
          • Absurd
            • Oct 2007
            • 118
            i used the 1087 code to get in and run sim 004 by hitting print twice once your in the sim.
            • jewen25
              • Mar 2009
              • 197
              tnx bro...
