Have a KM-2050 which makes dark copies after running a sheets through the doc feeder. The number is totally random. Turn the machine off and on again, and the copies are clear again.
Replaced the cracked slit glass and the connector/cable running from the doc feeder to the machine already but same problem.
When the machine starts making dark copies, the copies from the glass work fine. Only the doc feeder copies are dark and remain dark until the machine is turned off and back on again.
Any clues?
Any clues?
