km 4035 mac 10.5.6 printer install problem
  • n25an
    • Jul 2008
    • 1030
    I downloaded the printer driver for km 4035 to mac 10.5.6. It installed... according to the driver successfully...
    I then turned on netware and all the other options... on the copier...
    I installed the printer as appletalk printer... it installed...
    (side note: it came up bonjour and not appletalk )
    I pulled up the printer que... it stated the printer driver was
    installed improperly and cannot be used. Please try reinstalling it, or contact administrator
    I then attempted to print test page... it timed out in the que... no effect on copier...
    I tried setting it up as a lpd printer ... the same effect...
    any suggestions...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • n25an
    • Jul 2008
    • 1030
    update on printing to km 4035 from mac
    any suggestions...
    Ok... first the cable was bad... second if I use a postscript driver or try other kyocera drivers... I am able to print...
