Kyocera KM-1820 black lines
  • ebm
    • Apr 2007
    • 183
    Aloha,
    Has anyone else out there encountered random black lines generated on copies,faxes and scans using the KM-1820 ADF? I have tried turning on "scan noise reduction",cleaned scanner mirrors & lens,replaced scan glass,adjusted Mode 87. I have two of these models with this problem. I had to replace one machine for unsatisfied customer. Used the same ADF and fax board though. So I am looking at something in the main body as the problem. The other machine is used mainly as a fax so customer does not encounter the random black lines when they copy and they are not too critical of quality. I hope someone else has encountered this and was able to fix.
    Thanks.
  • Newman
    Lines when using ADF
    It's been a while since I worked on Kyoceras, but there is a simulation (I don't remember the sim number) "shading position" that actually adjusts where the mirror frame stops, which changes the area of the scan glass that it looks through...sometimes changing this setting will get rid of the lines. If that doesn't work, try to shift the position of the ADF itself at the hinges. Hope this is helpful!
    • ebm
      • Apr 2007
      • 183
      Maintenance Mode 87 is the adjustment that is supposed to change the position of where the scanner is under the slit glass when it reads originals. Funny thing is, I made a mark on the glass w/ a fine tip sharpie that generated lines but when I adjusted Mode 87 from one end of the adjustment to the other the lines never went away or moved position on the copies/scans. I can see the right hinge is adjustable for skew correction. I will see what the effect on scanning it makes. Thanks for the input Newman it is greatly appreciated.
      • achangcw
        Any luck in resolving your black line issue? My KM-1820 is almost new, less than 5000 copies but also had this problem. I emailed Kyocera and hope to get a response.
        • leroyal
          Expert on The Obsolete
          • Sep 2007
          • 156
          Originally posted by ebm
          Aloha,
          Thanks.
          Sounds like "noise" in the Scanner CCD.
          I know what I know better than anyone else knows what I know.
          • Mark B
            • Jul 2006
            • 153
            Go to system settings, turn scan noise reduction "on". This is also called, black line correction.
            • guru
              • Aug 2006
              • 18
              You may try Sim U074 "Adjusting the DP input light luminosity".Increasing the setting makes the luminosity higher, and decreasing it makes the luminosity lower.
              not outsourced yet ...
              • achangcw
                Kyocera Support
                The black line problem only occurs when the ADF is used. Kyocera Support says a shading adjustment is needed, the mirror in the scanner glass is not aligned. They suggest a technician which would cost $150+. The ADF itself is probably $200. Anyone knows if replacing the ADF itself would solve the problem?
                • achangcw
                  Problem solved
                  I thought I cleaned the surface glass and all surrounding area very well with a clean cloth but actually dust still remains in hidden area. A thorough cleaning with a Q-tip solved the problem! Thanks for all of your advise.
                  • al3andaleeb_s
                    you have to clean small class at right scanner platen
                    some dots or dump clean it just
                    • mrushing
                      • Mar 2008
                      • 27
                      i have a customer on maintenace who has had this problem several times, i have found the mylar on the adf that rest on the slit glass gets dust under it , once i clean it with denatured alcohol and caned air problem goes away for about 2 months before they have any further problems
                      • termacadon
                        IT goofball
                        • Oct 2008
                        • 66
                        Aloha,
                        Thanks.
                        Firstly, Did this solve your problem?
                        Secondly, Is it when printing out or scanning in and sending faxes aswell?
                        • aodtech
                          • 194
                          This has been a problem for any new 1820 that has been going out. Normally I just blow out the dust on the slip glass and clean it with alcohol. This has worked for most of them, however I had to replace the scanner on one to fix this problem.
                          • mrushing
                            • Mar 2008
                            • 27
                            1820 black line problem
                            I have found that a static charge on the mylar strips if you open up the adf its located on the part above the slit glass it is either 3 or 4 mylar strips that kinda hang down dust particles builds up on these causing the black lines, i just tried a static aresal spray that is supposed to repel dust also I used a dryer sheet on another customers machines, too early to tell if either one of these has solved the problem
