CS-1650 Doc Feeder
  • joelsa12
    • Nov 2008
    • 260
    CS-1650 Doc Feeder
    I apologize ahead of time if this has been posted before. I have read about this some where but could not find though searching. I have a CS-1650 and on the last sheet of paper that it fed through the Doc feeder it will make this squeaking noise. I have cleaned everything in this feeder with rubber rejuv. I am at a loss and help would be appreciated.
  • Absurd
    Just a brick in the wall
    • Oct 2007
    • 118
    If its just squeaking then cleaning rollers isnt going to help. it will probably be at some shaft/bushing point. put a drop of WD40 or take the bushing and clean with alcohol and re-lube with oil or grease.
    Southern Duplicating of Mississippi
    PSN: DrAbsurd (if you know you know)
    "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
