Kyocera C5200 error codes
  • drewd
    I have a C5200 printer that has the following error code.
    Call Service
    1010:0006592
    Anyone know what the problem is?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • LNorris
      • Sep 2008
      • 645
      check to see if tray is lifting or not
      1010 Lift motor error
      The main motor ready input is not given
      for 5 s during the main motor is ON.
      Defective bottom
      plate elevation
      mechanism in the
      cassette.
      Check to see if the bottom plate can move
      smoothly and repair it if any problem is
      found.
      Defective drive
      transmission system
      of the lift
      motor.
      Check if the rollers and gears rotate
      smoothly. If not, grease the bushings and
      gears. Check for broken gears and replace if
      any.
      Defective lift motor. Replace the lift motor.
      Defective engine
      PWB.
      Replace the engine PWB (See page
      • drewd
        Thanks.
        That worked perfectly
