e34 jams pf-650
  • PIPSTONE
    • Jun 2025
    e34 jams pf-650
    I have 2 machines with jam a 34 from PF 650 lcf and i have changed the feed belts feed rollers and both clutches the machine runs fine from all the paper trays but has very frequent jams from the lcf any clues???
  • 10871087
    • Jan 2005
    • 1062
    Where does the paper end up when a jam occours and what does it look like?
    • RTFM
      • May 2009
      • 14
      Remove all the paper from the left side of the PF, leaving paper in the right side, when the lift motors have lifted all the way, the pf then automatically feeds paper to the left side, if this clip is cracked or broken you will hear a grinding noise.
      When you pull out the feed ass'y from the PF 650, check to see if the black plastic clip is ok, the clip holds a clutch in place and you will find it on the left side of the unit, there is normally a silver earthing strip running underneath this clip. I know, there are a few clutches, but I think its the third one , counting from left to right.
      This clip forms part of the feed ass'y housing. I have found cable ties to work great.
