KM6330 and KM7530
  • Elridge
    • Jun 2009
    • 43
    KM6330 and KM7530
    Can anyone tell me how reliable the Kyoceramita KM6330 and KM7530 copiers were? I looking to purchase one of those models.
    • 30294
    old machine
    stick with 6030 or 8030
    or better yet falcon 2 or falcon 3 series
    machines are tanks
    • 10871087
      • Jan 2005
      • 1062
      They were OK at best when they were new, now they are 6-8 years old and not OK. Go with bsm2's advice and look for a newer machine.
      • aodtech
        • 194
        Just look at the specs. Warm up time 360 seconds or 6 minutes and that's at room temperature! And you have a paper jam and have to open the front door and close it, the machine will say "Now Cleaning" for a good 3 minutes each time. I would also agree with a used Falcon 2 or even Falcon 1 machine instead. So many less headaches.
        • vikingmita
          • Nov 2008
          • 163
          depends on their 'mileage'. on two important fields these machines are way better than their younger brothers: fuser and vacuum feeder. latter is totally superior, and i'd wish Kyo would release a new model with that and a less sensitive fuser/fuser exit.
          and hey: it's taskalfa 820 and 620 nowdays
          • rich2764
            • Jun 2009
            • 20
            km 6330 & 7530's
            These machines need both drive gearboxes stripping down and gear shafts cleaning after a million copies, otherwise you get a lot of c2550's plus the duplex bushings get clogged causing the same error. Also most of the feed and registration clutches go rusty causing jams. If you are prepared to spend time and money doing this work then you will be rewarded as these machines run really well.
