Error C2520
  • mick62
    • Aug 2025
    Error C2520
    Hello
    Could someone tell me what is the error message C2520 on Kyocera KM C850, and how can we reset the machine.
    Greeting
  • Jules Winfield
    • Jul 2009
    • 821
    Originally posted by mick62
    Hello
    Greeting
    That code refers to a problem with the paper feed motor. Check paper feed drive section (gears, motor). Also check wring between PF motor and engine board.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • mick62
      Hello
      I thank you kindly help me solved my problem.
      To check if my problem came from a paper trays, I disconnected all the bins and the result is the same "error C2520"
      Can you tell me what PF means between motor
      Can do a reset to restart the copier?
      • Jules Winfield
        • Jul 2009
        • 821
        Hello
        PF = Paper Feed
        Maintenance Mode 906 should take care of the reset...
        • mick62
          Hello
          Thank you very much for your contribution to help me overcome this problem.
          Greeting
