Kyocera FS-4020 print PDF too slowly
  • Realtech
    • Oct 2009
    • 103
    One of our costumer have a problem with two new printers Kyocera fs-4020 with 128mb ram.
    It started with one them the description below and now the another one.
    This costumer print a document consist of 5 pages PDF what happen is first 1 pages come out and you have to wait 4 seconds for the next pages and 6 seconds for the next pages.
    Sometimes a error log is generate ram disk not active or but the printer ram disk is on. In the same office there is a HP laserjet 1320 with 32mb ram it's printing PDF documents fine and fast.
    Any Idea? I need help.
    They use XP-Operating system, the driver are share on the server and must document are in PDF.
    Any Idea?
  • knobby
    • Oct 2008
    • 75
    sometimes it helps with pdf's if you configure the port as an lpr port, seems to make a difference on Ricohs, not tried on a Kyo yet
      • 29946
      try changing the PDL from Pcl xl to pcl5e
      • pcs
        • May 2009
        • 26
        Have you tried up dating the firmware?
        I know this works on other products with similar issues
        • n25an
          • Jul 2008
          • 1030
          make the printer driver spool then print... that often helps... it may take longer to start but prints faster in the end...
          Sad To Say I Don't Have a Life
          I do this stuff on the weekends too
