DC 2355 toner recycling tube
  • copyaction
    • Oct 2007
    • 991
    Don't laugh... customer would like to have it repaired if possible.
    cleaned out the tube but it is still shooting toner out the bottom.
    anyone know pn# or if it is still available...or a good used one
    ok... now you can laugh
  • happicopy
    • 51
    sounds like you got a problem with the mount, toner outlet -Pn 66018100, if you replace it, try to replace also the gears and bushings around it also, experience taught me the gear's teeth are most likely to be worn out. or maybe replace the whole cleaning unit (if you manage to find one). Cannot laugh about it...still got plenty of those clunkers running....
