KM-1128 skewing out of the box
  • Jimbo1
    • Mar 2008
    • 845
    Has anyone else had an issue with these machines and skew?
    We have had a couple out of the box with some wicked skew. Had to replace the laser in one of them. Not wanting to do that again if we don't have to.
    Got any takers?
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • dickierock
    • 252
    Hi,had 1 which was brand new not so much scew but had to send back because of mirrors out of position causing a dark copy,no image ,figured it was a one off,,
    • Jimbo1
      • Mar 2008
      • 845
      Thanks....we may have to hammerlock our rep...Mr. General...into coming and looking.
      Cdr. William Riker
      • Two Medicine
        • Sep 2007
        • 20
        I had one last week skewing about 3 to 4mm out of the box. Checked the shutters, etc and the registration unit. Even adjusted the buckle trying to find what was going on. Finally discovered that the developing unit was causing the problem by swapping with another machine. Skew immediately went away. The dev unit has a metal plate on the bottom that acts like a guide or something. Couldn't determine if it was the guide and/or just the way the dev assy sat inside the machine, but it was immediate. Put the old dev unit back in and the skew came back pronto.
        • protec
          • Feb 2005
          • 25
          The plate it is
          It's the plate. Exchanged one from another DV and the skew straightened.
          • Jimbo1
            • Mar 2008
            • 845
            OK. Plate. So what did you do to fix it besides swap it???????? Bend? Speak at it harshly??
            Cdr. William Riker
            • Jimbo1
              • Mar 2008
              • 845
              Ok so we took the plate off one and it quit skewing. Quality control anyone????????????????????????????????
              Cdr. William Riker
