c6000 error on CS-1820
  • Scott_Lewis
    • Mar 2007
    • 519
    I was new once.
    Reposted for WYOUNG
    Originally posted by WYOUNG
    I have would like to know if any one has had problems with the cs-1820 when they have changed fuser units it and it still comes up with the c-6000 error code when i replaced fuser i had top cover open it still did not reset code.
  • 10871087
    • Jan 2005
    • 1062
    Originally posted by Scott_Lewis
    I was new once.
    Reposted for WYOUNG
    I'm pretty sure you need to run a simulation to reset any of the fuser codes for this model. I think it might be 163 but I'm not 100% on that.
    • B0265
      • Jan 2007
      • 718
      If you can't enter service mode, try this:
      Power off, open top cover, power on and enter service mode.
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        Here's the real way to reset that fuser code.
        First open top cover then turn on power.
        press system menu/counter
        arrow down to service
        press and hold start, # then enter keys
        arrow down to maintenance
        press enter
        arrow down to Sim 163
        press enter
        select execute
        press enter
        turn off power then back on
        Hope this helps you
        My mission here on Earth is to help all you Dum-Dums!
        • 10871087
          • Jan 2005
          • 1062
          Do I get half points for getting close?
          • kyoceradude
            The Great Gazoo
            • Aug 2006
            • 442
            How about a hearty handshake and a pat on the back for trying.....
