Kyocera Falcon 3 Revisited (3050 4050 5050)
  • Copystar
    Superfreak
    • Jan 2005
    • 45
    How have your machines been doing since installing the latest firmware updates? Our machines have been running fine with just a few op panel speed comments from end-users. Has anyone had any actual mechanical issues?
    sigpic
  • just a tech
    • Jan 2007
    • 332
    none here ,so far...
    • knightfall
      • Jul 2006
      • 633
      the latest firmware has increase speed a little but I think customers have gotten use to the lag time.
      Get your facts first, and then you can distort them as much as you please.
      • nichjar
        havent had any mechanical problems so far (touch wood) - the new fw has got the customers happy with control panel speed, still a little slow at times
        • 10871087
          • Jan 2005
          • 1062
          Running great, still a little slow but OK with most users.
          • kyoceradude
            The Great Gazoo
            • Aug 2006
            • 442
            Seem to be running ok now with 2.04 (the NEW, new firmware). Had some issues with upper cassette showing add paper event though paper is loaded and lifted up. Reset disable reset problem. Had many machines that we had to remove and reinstall dimms to get rid of really wierd problems. I guess that was mostly on earlier machines. Our current population of Falcon 3's is around 100..
            My mission here on Earth is to help all you Dum-Dums!
            • dwparker.wa
              • Mar 2007
              • 33
              We only had one machine cause us problems. It was an upgrade from a Falcon 2, so they still are learning the ops panel. The only other problem we had was sabotage caused by one of the customers former employees. She set the number of copies in the user settings to 1, so the machine was only making one copy at a time.
              Parker
              • typerating
                We have had fuser error codes on three machines, the latest firmware upgrade has solved these problems, and the panel reaction speed is also tolerable. Will the pcu's last their aspirational 400/500K copies ?
                • 10871087
                  • Jan 2005
                  • 1062
                  The latest firmware (204b) added an interrupt button to the touchscreen and speed up things if you were browsing in the address book. I wish they had this shit figured out back when they launched this thing but I guess its "better late then never".
