c3200 error code
  • brancas
    • Jul 2009
    • 80
    c3200 error code
    Recently I removed the first Scanner mirror of a customer's KM-2550 to solve the white lines on copies problem. When I replaced the cleaned Scanner mirror a C3200 error code keeps coming up every time I make a copy. I changed the home position sensor and the scanner lamp according to the manual, but the problem still exists. Any help will b appreciated.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Are you printing to this machine?
    Are the image faults only coming from the reader?
    Did you check internal prints from service mode.
    • R1200gs
      • Mar 2010
      • 14
      My guess is that the mirror isn't installed correctly, maybe you switched the front and back?
      • Gavinassad
        • May 2010
        • 2
        Gavinassad
        Hi brancas; I don't know if you have sorted out your problem yet, but the mirrows must be put in upside down your row is giving off too much reflection,
        Good Luck
        • D_Ritter
          • May 2010
          • 16
          Seems like you have put in the mirror in a wrong position. Maybe upside down. Move it a bit and try again. It sometimes need some time to find the right position.
          Often this call appears when mirrors are dirty.
          Hope I could help you!
          • brancas
            • Jul 2009
            • 80
            I took out the scanner mirror and repositioned it again and it worked. Thanks for the help!!!
