km-2550 pin code to enter management mode
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    I need the pin code to enter the management mode you access by pressing system menu / counter key. The machine is Any help is much appreciated. When I try to enter these settings it prompts me for the pin code. Is it a standard code? Should I initialize all daa in service mode to reset pin?
  • blazebusiness
    • 1257
    ok...solved my own problem...pin code is model speed followed by 2 zeros...example KM-2550 - pin code 2500
    • alpha-omega tech
      • 80
      You can also try 6482 which spells MITA.
