error C6400
+ More Options
Posts
  • sunshy
    • Sep 2025
    error C6400
    After turning machine off, unplugging & turning back on, it continues to show that error msg. It won't let me do any of the solutions I read here regarding it? This began from a power outage for 5hrs. I'll be leaving in 15min for lunch, but w/return at 1pm. Hopefully someone will have compassion for me LOL Thanks in advance!
  • JustManuals
    • Jan 2006
    • 9838
    Don't you think it might help if you mentioned what model you're working on????
    • DWise
      • 895
      Manuals, Don't get caught up in the petty details!
      Do for one what you wished you could do for everyone. - Andy Stanley
      • sunshy
        Oops, yes sorry it's a Kycera KM3050, thank you
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
          Paul@justmanuals.com
          • lvsb
            • Aug 2008
            • 70
            C6400
            Zero-crossing signal problem
            โ€ข
            The main PCB does not detect the
            zero-crossing signal (Z CROSS SIG)
            for the time specified below.
            At power-on: 5 s
            Others: 5 s
            Execute 163 in service mode
            • jewen25
              • Mar 2009
              • 197
              Originally posted by lvsb
              C6400
              โ€ข
              At power-on: 5 s
              Others: 5 s
              "IvSB" is right execute 163,if its continues maybe the halogen lamp is damage,try to measure the voltage
              ERROR HELP ME AND HELP YOU
              • happicopy
                • 51
                maybe u mean heater lamps perhaps? 163 first if the problem is not corrected, check fuses and the HRlamps
                • jewen25
                  • Mar 2009
                  • 197
                  thats what i mean "happicopy"
                  • ignacio.cortez
                    • Jul 2010
                    • 176
                    C6000 Series errors are Fixing (Fuser) Unit issues, 99.99% of the time its just a matter of Running Sim 163 (which resets the Fuser Unit Error Codes) All other Locking codes use Sim 906. If you get an Operational Machine after it restarts, then you're come free, if not, depending on the code, you'll know if it is the Thermistor or Thermostat, or Broken Lamps.
