Copystar 4530 C610 HELP!?!?!?!
  • QUALITY IMAGING
    • Mar 2007
    • 20
    I just took in on trade a Copystar 4530. It has a C610 Code. Most likely a main board, right? Well here is the concern. The Company that held the Service Contract before put a new main board in this machine 8 months ago. I would hate to put a new one in , sell the machine (w/Serv. Cont.) just to have this go bad again in 8 months.
    Is there anything that would make the board go bad? Does anyone have any insight? I greatly appreciate your help.
    Thanks,
    Mike
  • Gman
    Check the DIMM(S) on the memory pcb. Good luck!
    • jpcopy
      • Apr 2006
      • 256
      you might want to check power where you just traded that machine in from
      • QUALITY IMAGING
        • Mar 2007
        • 20
        First Thing We Thought Too. The Machine Was Moved To This Location After 1st Board Was Installed. Power Is Clean At This Location. Any Other Suggestions Would Be Appreciated. Thanks
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          Just for giggles and grins, how many copies on the machine and has the PM been done? We've had issues with worn drums causing high voltage arc's, which can give you an eroneous code. We even had an issue with a drum carriage assy. To this day it still throws a code. Do you have another machine to swap the main pcb and or dimms? With a price of $1005.00 to repair pcb, much caution..
          My mission here on Earth is to help all you Dum-Dums!
          • Absurd
            Just a brick in the wall
            • Oct 2007
            • 118
            I have also seen a warn drum cause bad things to happen. Most often it will cause the dv bias to get way out of wack and pull developer.
            Southern Duplicating of Mississippi
            PSN: DrAbsurd (if you know you know)
            "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
