Mita DC 1470
  • mysticus
    • Feb 2007
    • 21
    Mita DC 1470
    This is an old copier..and should of been retired long ago. I just changed out the drum and reset the pm. When I tried to run 10 copies of 1 sheet it will copy one and then you have to hit the print button each time for each repeat. It still maintains the count 10, 9, 8, etc. I am hoping it is just an adjustment but also think it could be the print key.
    Any ideas or suggestions?
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    It's been a while but make sure sim 73 is set back to 0(zero). Did the change unit light go off or is it still blinking? When it's blinking you can only make one copy at a time. Sim 71 should be set at 30K.
    Hope this helps
    My mission here on Earth is to help all you Dum-Dums!
    • 10871087
      • Jan 2005
      • 1143
      only one copy at a time from a Mita means you need toner. Did you leave something unplugged?
      • mysticus
        • Feb 2007
        • 21
        you were right! I had used Intrivias guide and for a novice it is sometimes not so clear. Downloaded the service manual and went back and reset the pm code and problem was solved.
