Copystar 2540 C3200
  • joelsa12
    • Nov 2008
    • 260
    Copystar 2540 C3200
    I have a machine that keeps error coding. I have cleaned the optics. checked the home position sensor. i even replaced the scanner lamp. before i start to replace boards are there any other things that i can check?
    the machine can get a 906 and work for weeks. then it will code again. the end user says that she is not making a lot of copies when this happens. i do not know it i believe that. i did find some copies with half of the page light so i do really think that the expo lamp is not lighting up like it is supposed to, but and help would be appreciated.
  • jewen25
    • Mar 2009
    • 194
    try to check the scanner flex cable if its broken,or replace another one to sure if its the damage
    ERROR HELP ME AND HELP YOU
    • dickierock
      • 252
      Hi have u done the firmware?
      • joelsa12
        • Nov 2008
        • 260
        yes the firmware is current. i am waiting on the inverter PCB to arrive. I will let everyone know after I install it
        • Frits
          • Jun 2009
          • 62
          I had this before and you are right to replace the inverter PCB this will solve your problem
