Taskalfa 400ci in europen - in american model is there a difference
  • land1
    • Jul 2025
    I will buy toner for taskalfa 400ci ,If ı buy in USA can ı use it in Turkey
    In Turkey toners are very expensive
    I see that there is 3-4 models toners tk-859,tk-857,tk-855,tk-853 What is diffrences...
    and also Spare parts are diffrent or same and can use in Turkey if ı buy in USA ?
  • 10871087
    • Jan 2005
    • 1062
    What is your standard power setup in Turkey? are you 230vac # 50hz like the rest of Europe. If that is the case the the US machine will need a pretty expensive power converter.
    • land1
      230vac # 50hz like the rest of Europe >>>correct...
      pretty expensive power converter. >>> ????
      looking for toner...
      • Joel
        • May 2010
        • 46
        I think toners from the US is same as toner from Turkey, you can inquire from the US for the product code for your machine. Same as here in the Phils. toners are same from Japan, Singapore and US as long as their product codes are same.
        • land1
          For example in europe tk-855 thesee code you can find and also in my machine...
          In USA tk-859 you can find ?
          tk-855 code toner you can't find in USA
          • land1
            tk-859 toner soen't work in taskalfa 400ci europe model...
