Hello guys i read in SM the error is in the Bitmap(DIMM)or in the main board kp-5060,its probably it can be repair? pls give some idea for this thanks
KM-1500 Error C-0610
might possibly try updating firmware. I know kyocera has addressed the c-0610 error in other models before with firmware changes. If you go with the firmware solution don't forget to move the jumper switch before and after the upgrading process. you'll have to order part # 2BZ01180 for the flash dimm. Can find upgrading info on page 1-7-1 in the service manual. If you order it, it should automatically come with latest version of firmware already installed on it. (latest should be ver. 124 I believe)
