Setting up a KM-C2230 / Minolta CF-2203
  • Spank6482
    • Feb 2005
    • 66
    How long does it take to unbox and set-up a Kyocera Mita KM-C2230 (Konica Minolta CF-2203)? We have sold a few and they take our tech forever to set-up. Most of the current Kyocera's set-up pretty quick but not this thing.
  • backyard mechanic
    Re:Setting up a KM-C2230 / Minolta CF-2203
    On those machines they do take alittle bit longer to set up because you have to go through the setup 3 times. Otherwise it will produce a gray image on the page when copying.
    • 10871087
      • Jan 2005
      • 1062
      I like the big grey square on all the copies that shows up if you forget to set the date/time at setup. That took us 2 hours and a call to the hotline hmy:
      • cboucher
        • Aug 2025
        It should take about 2 - 3 hours for a base model type machine and 4 - 6 hours for a fully loaded machine (testing time included).
        • cboucher
          • Aug 2025
