Taskalfa 300Ci, code C9500?
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    manual says contact service admin depot.
    Does this mean anything?
    Idling colour developers are not healthy developers.
  • Copier
    • Jan 2007
    • 27
    I think that is the code if you try to copy money.
    • nathicana
      • Aug 2008
      • 335
      Hello,
      Did you find the solution for a C9500 code? I am battling a C9530 on a 400ci. The service manual says "contact service administration". The Kyocera hotline doesn't give me specific causes other than checking connectors at the engine board. I have replaced the main board, engine board, power source board, main dimm and hard drive. I have heard a rumor that the secret codes are related to counterfeit protection. My original engine board had a burned spot and a bad electrical smell. Have you looked at yours?
      • kevin-fisherman
        same code on 420i
        what i found is that if you have a fax board remove it see if you get the error.
        run flash
        • flimmer
          • Jun 2008
          • 30
          The connector on engineboard upper right corner - metal cover - did not connect correctly - had this error yesterday
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            More like trying to do gray adj with bonds.
            Loose connector, will keep that in mind.
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              More like using bonds for gray adj.
              • Dispatcher01
                • May 2010
                • 11
                We had a client call in with a C9500 code and then when the tech got there , there was also a CF126 code came up on the machine. The tech called Kyocera tech support and they searched around and found that it is a communication code with the DP. The tech messed with the connectors to the DP760 and the machine is working, he is ordering the CIS Cable Connector Cover Set (old part number 855D500018) new part number 303LK94050 ,to install per tech bulletion taskalfa 250ci/300ci #TB2R1.
                • Arc Angel
                  Junior Tech
                  • Jul 2012
                  • 65
                  Re: Taskalfa 300Ci, code C9500?
                  Having the same problem with a task alfa 250ci machine. It continues to give me a C9530 error. I've checked for loose connectors, and I have changed the main board, and the engine board. Is there any way of resetting this error code.
                  The secrete of staying young is to live honestly, eat slowly and lie about your age..... No man is so poor as to have nothing worth giving.
