TaskAlfa 420 and LDAP
  • basta63
    • Aug 2025
    Hi.
    I'm trying to add to your address book contacts from ldap but nothing comes out.
    By steps:
    1. Go to Command Center
    2. Advanced
    3. LDAP
    LDAP: ON
    LDAP Server Name: 192.168.0.1
    LDAP Port Number:389
    Search Timeout: 60
    Login User Name: admin
    Login Password: admin
    Max Search Results: 255
    Search Base: dc=company,dc=local
    Ldap encryption: off
    Submit.
    On machine - SEND key, go to Address Book, chosse External Address Book and ... External Address book not avalible.
    PS if i start KM LDAP converter it returns me all the records that are without problem.
    Help me plz, what am I doing wrong?
    Thank you.
  • Frits
    • Jun 2009
    • 62
    if there is windows 2003 server you have to enable anonymous access to Ad.
    if you need the manaul for it and the files let me know
    • basta63
      Oh, thank you, but i am fix my problem
      Login: cn=admin and it works ))
      But! there was another problem. Kyocera sorts the list by name, but not by lastname! Even if the Command Centr to specify - "sort by lastname"
      And how can we add to the usual address book - contacts from the files, for example .csv? and then adds an manually each - a very long time.
      Thank you.
      • Frits
        • Jun 2009
        • 62
        if you select an item in the external address book you will be able to save it to the usual address book.
        if you have an old version of km netvieuwer 4.xxx you will be able to upload csv.
        if you need the old version let me know.
        • basta63
          Save from external book to usual addressbook to do with km netviewer?!
          Give me plz old version. Thank you!
          • Frits
            • Jun 2009
            • 62
            No, if you select on the machine an item in the external addressbook you will be able to save to the usual addressbook.
            with the old version of km netvieuwer you will be able to upload a csv to the usaul addressbook.
            i will post a link for the download for the old version of km netvieuwer
            • Frits
              • Jun 2009
              • 62
              • basta63
                Ok! Thank you so match!
                I ll try tommorow and report
