KM-2530 time for maintenance
  • Hal
    Called out to look at a this machine. It is working but making splotchy copies/prints and displaying the "Time for Maintenance" on the panel. I cleaned the corona wire and the rotary scrubber sponge that contacts the drum. There are striped and blotched areas of toner baked on the drum. I know these are causing the poor print quality. Is there a safe way to clean the drum.. ie iso. alcohol or anything else.. or will this make things worse?
    Is there a reset to turn off the maint. display or is this a call for the BIG ONE for the warranty that must be done?
    I don't happen to have a manual for this unit..
  • dogsbody
    • Jun 2007
    • 289
    If it's time for a service get a maintenance kit (MK-705) and all will be sweet.
    The force will be with you always.
    • Hal
      maint & drum clean quest
      Thanks amigo! That's what we'll do then .
      • Copiersrus
        As far as the toner on the drum, put 11x17 paper in bypass hit asterisk and drum refresh this will rub the toner off it may take a time or two. also it will make an annoying sound. Sim 203 or 204 reset maintenance counter. Also check your toner only the generic (pirate) toner does this, that I have seen.
        • adriansto
          • 2383
          I have a KM 2530 and the developer tank is full with toner. On LCD screen appears ' Adding toner ' and the copier is not working. Please a service manual for this unit. My mail stoadis@gmail.com
          Thanks!
          • Copiersrus
            Check your email.....
            Good Luck
            • milan
              • Jan 2007
              • 25
              Thanks!
              there is a modification for this particular problem see attached file
              • adriansto
                • 2383
                Thanks !
                I will verify this.
                • bariskurt23
                  • 16
                  first 1087 1087 set developer
                  if not run
                  check toner hopper solenoid , gear and belt
                  • LNorris
                    • Sep 2008
                    • 645
                    if the copy quality is still good, you can run sim 251 and clear the count and the message will go away. you can also set sim 250 to 0 and the message will never show again.
