Hi Guys Please I Need Help With My Kyocera It Only Has One 2 Years And Send Me An Error Message,c6000 Could You Tell Me What To Do So I Can Fix It.thank You.
Ivan.
press these keys in this order and keep holding them down " start"key and left"#"key. press"enter" key. then enter the code number with the up/down arrow keys . press the "enter" key after the item is run press"back"key exit the mode by shutting power
u 163 reset fuser errors press "enter"choices will display select "execute" press "enter"to clear
