how to store scan doccument in HD in km 3035
  • dipakpatel
    • Sep 2010
    • 34
    [Misc] how to store scan doccument in HD in km 3035
    i have km 3035. i want to store scan doccument in HD.
    pl guide me.
    thanks
  • wellconnected
    • Oct 2010
    • 23
    When you send originals, this feature allows you to store a copy of the
    document being sent in a Document Box.
    The procedure for using Send and Store is explained below.
    1
    Place the originals on the platen.
    2
    Press the Send key.
    3
    Press [Advanced Setup], [��], and then [Send and Store].
    4
    Press [On].
    5
    Select the Document Box in which the Send and Store copy is to be stored.
    If a password entry
    screen for the
    Document Box
    appears, enter the
    password.
    NOTE:
    The response to password input differs depending on whether or
    not user login administration is enabled.
    If a password has been set for the Document Box and login administration
    is enabled, there is no need to enter the password if the user currently
    logged in is the owner of the Document Box. Otherwise, the password
    must be entered.
    If the current user is not the owner but is logged in with administrator
    privileges, there is no need to enter the password.
    6
    Press [OK].
    Status 10/10/2007 10:10
    Ready to send.
    Destination
    Add Shortcut
    Store a copy of documents to be sent
    in the document box .
    Cancel OK
    Send and Store
    Enter Destination.
    0
    Off
    On
    Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
