I have a desktop FS-1128MFP that will not print from my MAC via the network. It will work with the USB from my PC. The Appletalk is on. Anyone know what I can check?
Will not print from MAC
If you are trying to use the network then use the settings below assuming that you have installed the driver.
1. Add printer from System Preferences
2. IP Printing
3. HP JetDirect Socket
4. IP Address of the equipment
5. Select the correct driverPlease don't ask me for firmware or service manuals as refusal often offends.Comment
