Kyocera KM-5035 system error 0730
  • gidon
    • Sep 2008
    • 3
    we have 2 KM-5035, constantly display system error 0730,turn off and on ,it will reset.
    any helps, thanks.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from Just Manuals | The Internet's largest collection of manuals | Instant Downloads
    Paul@justmanuals.com
    • correo.tony
      • 72
      Don't exist this error in Sevice Manual, reload error in operation panel !
      Bye !
      2FD/2FF/2FG
      1-5-24
      Code Contents
      Remarks
      Causes Check procedures/corrective measures
      C0640
      C0820
      C0830
      C0860
      C0870
      C0880
      C0890
      C0900
      Hard disk drive problem
      • The hard disk drive cannot be
      accessed.
      Fax control PCB* CG ROM
      checksum error
      • A checksum error occurred with the
      CG ROM data of the fax control PCB.
      Fax control PCB* flash program area
      checksum error
      program of the fax control PCB.
      Fax control PCB* software switch
      checksum error
      software switch value of the fax
      control PCB.
      Graphics data transfer problem
      • High-capacity data transfer between
      the fax control PCB and the main
      PCB was not normally performed
      even if the data transfer was retried
      the specified times.
      Program archive problem
      • When power is turned on, the
      compressed program in the Flash
      ROM on the fax control PCB was not
      successfully decompressed.
      Fax control PCB* CG FONT archive
      problem
      compressed CG font in the Flash
      Fax control PCB incompatibility
      detection problem*
      • Fax software is not compatible with
      MMI software.
      Poor contact of
      the hard disk drive
      connector
      terminals.
      Defective hard
      disk drive.
      Defective main
      PCB.
      Defective fax
      software.
      Defective fax
      control PCB.
      Defective fax
      software.
      Defective fax
      control PCB.
      Defective fax
      software.
      Defective fax
      control PCB.
      Poor contact in
      the connector
      terminals.
      Defective main
      PCB or fax control
      PCB.
      Defective fax
      software.
      Defective fax
      control PCB.
      Defective fax
      software.
      Defective fax
      control PCB.
      Fax software
      version is earlier.
      Check the connection of connectors YC49
      on the main PCB and hard disk drive, and
      the continuity across the connector
      terminals. Repair or replace if necessary.
      Run U024 (HDD formatting) without turning
      the power off to initialize the hard disk.
      Replace the hard disk drive and check for
      correct operation if the problem is still
      detected after initialization.
      Replace the main PCB and check for
      correct operation.
      Install the fax software to Ver. 2.xx or later.
      Replace the fax control PCB and check for
      correct operation.
      correct operation.
      correct operation.
      Check the connection of connector YC44
      on the fax control PCB and the main PCB,
      and the continuity across the connector
      Replace the main PCB or fax control PCB
      and check for correct operation.
      correct operation.
      correct operation.
      Check the version of fax software and
      upgrade it to a version that accommodates
      the machine.
