Kyoecra FS- 8008 print problem
  • drazen7777
    • Sep 2010
    • 40
    [Misc] Kyoecra FS- 8008 print problem
    I have a problem with mentioned kyo , and the problem is this , every second , third fourth or so , print came out like it is washed out , did someone had similar problems and could give me a hint?
    Regards
    Drazen
    Technician -- a person who fixes the mistakes made by engineers.
  • taskalfaman
    • Nov 2009
    • 137
    hi,
    in the past i had the same problem.
    check whether the solenoid of the sec transfer is not "hanging", are releases too late.
    please also check the clutches of the dev. units;
    • drazen7777
      • Sep 2010
      • 40
      Thanks for reply , i solved it last week . You are wright ,the problem was with the solenoid of the secondary transfer(all rusty inside) he was late and give me a lot of trouble until i figured out that he was the problem. Thank you again . Best regards.
      Sent from my HTC Desire using Tapatalk
