Fax Cover Sheet
  • monstott2010
    • Aug 2025
    Fax Cover Sheet
    Is it possible, on any old or new models of Kyocera/Copystar machines to program an automatic cover sheet to be sent when sending a fax either from walk-up fax or network fax?
  • shep
    • Sep 2010
    • 108
    I know for a fact that you can in network fax. we have a customer that uses it on a 300ci. you can save a fax cover sheet to the document box not sure on all the steps to get it set up right though.
    • nmfaxman
      • 1702
      Most LAN fax drivers come with an address book and coversheet built into the driver.
      I don't know of any machine that comes with an automatic Cover Sheet using the machine as a stand up fax.
