how to print event log
+ More Options
Posts
  • e007
    • Jan 2011
    • 13
    I have a question: how to print event log on kyocera printers without network card or parallel port. As an example FS-1300d. I think that exist some application to do this. Or maybe some comand on compact flash card.
  • HenryT2
    • 962
    It's been a while since I've had to do this...but: I think this will work. Good luck
    In the properties for this printer, set it to SHARE and give it a name. ex: 1300
    Open a command prompt: type net use enter
    type net use ltp3 \\ 127.0.0.1\1300 enter
    type net use enter ( check to be sure the printer is shared )
    type ECHO !R! ELOG; EXIT;>lpt3 enter
    Hope this works for you.
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • e007
      • Jan 2011
      • 13
      Thank you. It works .
      • madas
        • Aug 2008
        • 313
        Hi, Just as a reference guide.
        You can use this on most if not all models of Kyocera printers.
        madas
