Taskalpha Colors
  • alpha-omega tech
    • 80
    Taskalpha Colors
    How do you get any good colors from a Taskalpha 4ooci? I have one that when you copy the colors are not even close on business color not photos. The grays have a tough of magenta tint to it. Prints are better but not correct. I have replaced The CCD, developer units, and drums. Did laser clean, drum refresh, developer refresh, color calibration, color registration, and auto gray adjustments. Any suggestions?
  • Ausand
    Have you udated the firmware and can you post a color reg sample
    • Eric1968
      • 2458
      x2 for the firmware. BTW, that's an expensive repair, you're not going to make money with this machine.
      • MadCityCopy
        ieeeee
        • Oct 2010
        • 58
        And i thought I had problems with the Task colors.
        keep us updated. These things are handfulls. I have replaced several engine boards already.
        • JSC
          Gimp
          • Dec 2006
          • 618
          Ditto on the firmware (v11) and vac out/ clean the machine, clean ID sensors, make sure you do simm 464 Ac cal, 410,412 & try loading the bizhub colour table, which you should be able to get from your RTM if you havn't already got it.
          Post some samples if you can.
          Good Luck
          The gene pool could use a little chlorine.
          • alpha-omega tech
            • 80
            Replaced the color drums and developers and the colors are good again.
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              try different emulation. The latest driver has pdf emulation enabled.
              Idling colour developers are not healthy developers.
