Taskalfa420i - intermittent sticky key pad entries
  • MFPTech
    • 486
    Any ideas please?
    Thanks in advance!
  • Metalvoc
    • Sep 2008
    • 155
    You are having multiple characters entered for a single key press? Does this happen only when using the key pad, or also the on-screen keyboard? Take the operation panel apart. The key pad keys are all molded together. Make sure that none of those little plastic bars holding them together are broken.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • T911
      • Jun 2007
      • 628
      if your talking about the numeric key pad, someone spileed coffe on it. if you r talking about the lcd then update firmware if its not the op panel after you rip it apart. recalibrate the lcd too.
