Taskalfa 300ci black and white only
  • Realtech
    • Oct 2009
    • 103
    The default is in full color.
    When you print or copy a document you get only black & white document not in color.
    Any Idea?
  • Absurd
    Just a brick in the wall
    • Oct 2007
    • 118
    some one has locked color mode? I know there is a way to restrict use.
    Southern Duplicating of Mississippi
    PSN: DrAbsurd (if you know you know)
    "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
    • Sayen's
      • 20
      Either your job accounting settings are set not to allow you to do color or if your not using accounting check toner, there is a setting in the machine to only allow B/W when color toner is out.
      • aabarnes1
        • Mar 2009
        • 620
        Print out a status page to see toner levels, there is an option to copy in black and white only when colour is out. Otherwise check your default settings
        Grant me the serenity to accept the things I cannot change.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          system menu>common setting, 2nd page.
          You could run upward to 500 page of B&W with color out, per manual. BUT~! You cant use this feature when one of the color is already empty.
          Idling colour developers are not healthy developers.
          • philmyatt
            Re: Taskalfa 300ci black and white only
            Any Idea?
            did you find a solution to this problem? I have the same issue and can't find a way of restricting other than Job Accounting and that gives a different message
            • philmyatt
              just been told by another source to:
              1. remove all toners, close front door, check it
              2. turn main off/on, check it
              3. insert 1 toner, check, turn off/on, check
              4. insert next toner, check , turn off/on, check
              5. insert next toner etc, until fault cleared
              • 20gaugeO/U
                • 557
                Agree with Phil, just had the same problem when yellow dev crapped out. Replaced and wouldn't copy/print in color.
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  All that does is reset the percentage of toner that the machine indicates, i bet one of the color toners is near empty(usually yellow), the machine is set to allow copies in b/w when color toner out. These machines are known for false toner level readings, usually indicating 70% after customer has removed toner, shook it and reinstalled.
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                  • PassMeTheTools
                    • Sep 2010
                    • 7
                    Follow the steps Phil Mentioned. If a toner is nearly empty it is easy to tell by the weight of it. Just replace it with a new one.
