KM6330 C7300
  • dickierock
    • 252
    KM6330 C7300
    Have problem with C7300(toner empty sensor).Seems to occur when the machine goes into "adding toner"mode.It tries to replenish for 5 minutes,then C7300.
    So far,replaced toner empty sensor once,tested 1500copies,ok,call came back after 30k(maybe when toner empty detected?),
    Just to be sure replaced sensor again,checked operation using u137,seems ok,checked hopper thoroughly for correct operation,Firmware done,replaced dev in another dev tank,ran u130,set-up fine,ready to copy.Ran 200 copies normal,ok,then 50 sky shots to induce "adding toner" mode,5 minutes later C7300!.Checked U137 again,sensor ok.
    The customer not using Genuine Toner(i know!) but its the same toner for the last 1 1/2 years,problem only started 2 weeks ago.
    I know theres toner going into the dev tank cause its actually overtoning.Why C7300 and not C7100 error for toner density sensor? Any Ideas?my next move maybe,clean out,new dev,genuine toner,toner density sensor..Thanks in advance..
  • CT Copier Repair
    • Mar 2010
    • 304
    Non OEM toner
    it sucks on any mono component only OEM
    or try Only OEM
    • dickierock
      • 252
      Ct,agree but why now if the same toner for 1 1/2 years and why 7300 instead of 7100?
