I have a Kyocera KM-6230 machine. This is a monochrome multifunction machine. It has a code, C220. I need to know what this means and if anyone has a list of these trouble codes and a manual I would really appreciate the help.
KM-6230
dcopy
C220 is one of the paper feed tray lift motor is not lifting up. if you are a technician then check the lift motor or blockage of the tray if not then call for service. Check with manuals4you (a member of this forums) or post a request in service manual request.Get your facts first, and then you can distort them as much as you please.
