I have been having a kyocera go into a CF26F code in the middle of printing multiple print jobs (over 300 jobs). Alone the massive amount of print jobs is crazy, which I had to add memory to get it print better. However, now after printing maybe a little over 100 papers (varies) it goes into this code and will generally finish the rest of the print job after. Unfortunately, this is unacceptable as the copier loses the prints in memory and causes someone to have to turn it off then back on to continue.
EDIT: also I do not have a way to get the latest firmware, but if anyone can send me the latest engine/system firmware for the FS-1128 MFP I would appreciate it. billscm@coxinet.net
