FS-C2026MFP error 1102 when Scan to Email
  • terious
    • Jun 2025
    [Error Code] FS-C2026MFP error 1102 when Scan to Email
    Hi,
    We have FS-C2026MFP installed with Accounting and User Login activated.
    I have set up the SMTP and POP3 thru Command Center with the valid email account and password.
    If we try to scan to email, for any user we got error 1102. Only in case that user DeviceAdmin(2600) is logged the scan to email works perfect.
    Any ideas are welcomed!
  • Kyocop
    • 69
    Re: FS-C2026MFP error 1102 when Scan to Email
    Originally posted by terious
    Hi,
    Setup a new user called "scans" or whatever and give it full admin rights. Then route through that.
    • terious
      Same result... 1102...
      • n25an
        • Jul 2008
        • 1030
        Please detail the steps you used to setup the accounting and user login and smtp and pop and please outline in the order that you set everything up... I need some more details...
        Sad To Say I Don't Have a Life
        I do this stuff on the weekends too
        • terious
          Hi n25an,
          What I did was:
          - to enable user login with Local Authentication
          - to create two users: one with Administrator and one with User privileges. Both are on Others account.
          - unknown id job is by default - Reject
          - job accounting is by default - disabled
          - thru Command Center I have set the SMTP and POP3(after set to Off)
          After these steps was done:
          - login as id with Administrator privileges: printing and copying are ok. Scan to USB is ok. Scan to e-mail results in 1102 error
          - login as id with User privileges: printing and copying are ok. Scan to USB is ok. Scan to e-mail results in 1102 error
          - login as DeviceAdmin (2600/2600): printing and copying are ok. Scan to USB is ok. Scan to e-mail is ok
          - disable the User Login: printing and copying are ok. Scan to USB is ok. Scan to e-mail is ok
          From step 3 I got the conclusion (and also from reports received) that the problem is not in the SMTP settings.
