I'm going round all our machines and setting them up to email their counter readings at the end of the month. I have no problem doing this in general with newer machines when I install them.
My question is regarding the KM1650 and 2050, I've worked little on these machines.... they were a little before my time
Neway, I tried to do this at an office the other day, they also have a Taskalfa 250ci which I set up and is sending reports back no problem.
The 1650 however refused to play ball, first I wasn't even sure if there would be settings for it as there is no scanner board but I logged in to the web interface of the printer board and there it was, albeit with a few less options. I set it up as I normally would:
smtp: on
server: our roaming smtp ip address
authentication: via pop acount1
pop3 is again our own server ip address
login details of the email address I setup
both pop and smtp "tests" complete fine but when I try the send now function it just says error.
smtp: on
