Smarttech c8990 code- finisher comm error
  • Jimbo1
    • Mar 2008
    • 845
    Has anybody else had this code on their Smartech machine? It basically locks the machine up when it happens. No reset unless you just power off and on.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • ScrewdriverX
    Re: Smarttech c8990 code- finisher comm error
    I got the same problem. The error occures often after transporting the System. There is no description in the service manual about it. I found out, that the problem is in the bridge unit (AK470).
    After removing and installing it for a few times the error C8990 disappeared and now the system is running since a couple of weeks.
