CF000
  • djs
    • Jul 2025
    [Error Code] CF000
    Cf000 cannot get cs 305 to run. Welcome screen comes up and thats all.
  • BIG PAPA
    Da Boss
    • 234
    Re: CF000
    F000 Main PWB - operation panelPWB communication error
    Defective mainPWB.Turn the main power switch off/on to restartthe machine. If the error is not resolved,replace main PWB (see page 1-5-33).Defective operationpanel PWB.Replace the operation panel PWB and
    check for correct operation.
    sigpic
    • luis8832
      • Dec 2008
      • 250
      Re: CF000
      this might help you outflowchartr1.pdfflowchartr1.pdf
      • JustManuals
        • Jan 2006
        • 9838
        Re: CF000
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • kyocera.team
          • Aug 2010
          • 126
          Re: CF000
          change DIMM main board
          • AGI
            • Jul 2011
            • 17
            Re: CF000
            Did you install the memory upgrade? If you did, check to make sure it's seated in the slot properly.
            Authorized Kyocera and Konica Minolta Dealer in NJ
            Sales Site
            Customer Site
            • marc
              • Feb 2010
              • 56
              Re: CF000
              replace the operation panel and the DIMM code (set)
              • imaan
                • Sep 2016
                • 11
                Re: CF000
                I had the same problem with my Kyocera 2126, showing cf 000 after poking the machine. and now when coming up doesn't bother to load, it shows CF 020 error/
                wondering how I can sort it out.
                any idea where I can get the firmware for this machine?
                regards
