Scan setup for 2550 and 3035 on Windows 7
  • Sam Tofu
    • Dec 2007
    • 130
    Trying to set-up SMB folder's for these 2 machines. 3035 instructions seems straightforward.
    But 2550 isn't. We are not used to the Kyocera's for scan. Read through the 2550 set-up manual which seems to jump ya back and forth through sections.. Installed scanner file utility, able to see scanner via browser, added computers path and set-up address. In the 2550 when trying to scan says PC not on.
    Any tips or is there a clearer instruction download other than what is the basic set-up manual?
  • jummamaster
    • Mar 2009
    • 99
    Re: Scan setup for 2550 and 3035 on Windows 7
    SMB scanning in not available in KM2550. You can scan only through utility.
    Ricoh Error Codes
    Canon Error 5100
    Canon Error B200
    j
    c
    • ru4real
      • Aug 2011
      • 13
      Make sure you give your firewall an exception to allow the file utility program.
      • JR2ALTA
        • Feb 2010
        • 2031
        This "Scanner File Utility" is not something worth instructing within our forum.
        It's easy when you're used to it, but for now you should consult with a local pro.
