KMC 3232E touch screen issues.
[Electrical] KMC 3232E touch screen issues.
Are there any tricks to getting the screen calibrating correctly. I took it apart, carefully, and cleaned everything sensible. I put it back together and it started working...for two days! The further up the screen you go, the farther it is off. This is dangerous to take apart with those little ribbon cables. What actually goes bad?
happy boy
Re: KMC 3232E touch screen issues.
The only thing that really works is cleaning,watch out for kinks in the ribbon cable!The outer glass has something like x and y axis that id where u press!
Cleaning or replacing! -
Sounds like the operation tablet is going out. Replacing it should solve your issue. Watch when you order it, the four sponges on the edge of the tablet do not come with the tablet, they have to be ordered seperately (as I never remember to do this I usually have to carefully peel the old sponges off and attach them to the new tablet). The sponges are items 6&7 of the operation unit parts list--order 2 of each.If at first you don't succeed, redefine successComment
