c-6400 code for cs-1820
  • mthomp
    need reset for this code
  • Copydoc Ric
    C-6400 Reset
    This is a fixing unit error code. to reset use maintenance code U163. When a service call concerning the fixing section occurs, open the front top cover with the service call displayed and press the system menu/counter key to enter the maint. mode. Press the system menu/counter key. Select "service setting" using the up down cursor keys. While pressing the start key and the # key press the enter key. Select "Maint. Mode" using the up/down cursor keys. Press the enter key. Enter the maint. item number using the up/down keys. Press the enter key. The selected item is run. Press the back key.
    Doc Ric
    • mthomp
      u163 reset
      thanks for the help
      mark
