scan smb with win 7
  • marley
    • Sep 2010
    • 58
    scan smb with win 7
    Hello... I have set up a kyocera ta 250ci with smb. PC is a windows 7, I shared the folder and various permits, but does not work. Who can give me a help .... thanks
  • Kelvinator
    Re: scan smb with win 7
    Try changing the smb port on the web page address book to prt 445 instead of the standard port 139
    • taskalfa
      • Jun 2011
      • 97
      When to try to scan what error do you get. Try using computer name instead of IP address as HOST or vice versa. Make sure that the pc has a login password. Check if their is a domain name.
      • callservice
        • Sep 2011
        • 26
        with the above settings try this also.create a local user in the name of scanner and give a static password.share the folder with all rights to all local users. best of luck.
